是不是Debian13系统还不支持IMX219摄像头?
接入普通版本的树莓派5 imx219摄像头后,/dev/video节点还是只有
$ v4l2-ctl -A
cam-req-mgr-devnode (no bus info):
	/dev/media0
	/dev/media1
msm_vidc_media (platform:aa00000.video-codec):
	/dev/media2
msm_vidc_decoder (platform:msm_vidc_bus):
	/dev/video32
	/dev/video33
使用ffplay都播放不了,应该是没初始化正确。
内核方面貌似也没开启
$ zcat /proc/config.gz |grep -i imx219
# CONFIG_VIDEO_IMX219 is not set
当前采用的camera架构,imx219 sensor不是以/dev/video节点形式显示出来的
您可以连接imx219,参考user-manual执行gst命令,进行预览/拍摄/录像
好的。看来我的gstreamer被我更新搞的没插件了 :sweat_smile:
我重刷一下系统再试试。
重刷了Debian13,运行手册里面的命令gst-launch-1.0 -e qtiqmmfsrc camera=0 name=camsrc ! video/x-raw\(memory:GBM\),format=NV12,width=1920,height=1080,framerate=30/1,compression=ubwc ! queue ! waylandsink fullscreen=true async=true
提示 WARNING: erroneous pipeline: no element “qtiqmmfsrc”
可以确定Debian13并没有这个插件。
装完高通Linux后第一时间确认了
rubikpi:~$ gst-inspect-1.0 |grep qti
qtibatch:  qtibatch: Batching stream buffers
qtimetamux:  qtimetamux: Meta muxer
qtimetatransform:  qtimetatransform: Meta Transform
qtimldemux:  qtimldemux: Batching stream buffers
qtimlmetaparser:  qtimlmetaparser: Meta parser
qtimlqnn:  qtimlqnn: QNN based ML plugin
qtimlsnpe:  qtimlsnpe: SNPE Machine Learning
qtimltflite:  qtimltflite: TFLite Machine Learning
qtimlvclassification:  qtimlvclassification: Machine Learning image classification
qtimlvconverter:  qtimlvconverter: Machine Learning Video Converter
qtimlvdetection:  qtimlvdetection: Machine Learning image object detection
qtimlvpose:  qtimlvpose: Machine Learning Pose
qtimlvsegmentation:  qtimlvsegmentation: Machine Learning image segmentation
qtimlvsuperresolution:  qtimlvsuperresolution: Machine Learning image super resolution
qtimsgpub:  qtimsgpub: Message Publisher Client
qtimsgsub:  qtimsgsub: Message Subscriber Client
qtiobjtracker:  qtiobjtracker: Object Tracker
qtioverlay:  qtioverlay: QTI Overlay
qtiqmmfsrc:  qtiqmmfsrc: QMMF Video Source
qtiredissink:  qtiredissink: QTI Redis Sink Element
qtirestrictedzonedbg:  qtirestrictedzonedbg: Restricted Zone Filter
qtirtspbin:  qtirtspbin: RTSP streaming Bin
qtismartvencbin:  qtismartvencbin: Smart Video Encode Bin
qtisocketsink:  qtisocketsink: QTI Socket Sink Element
qtisocketsrc:  qtisocketsrc: QTI Socket Source Element
qtivcomposer:  qtivcomposer: Video composer
qtivoverlay:  qtivoverlay: Video Overlay
qtivsplit:  qtivsplit: Video stream splitter
qtivtransform:  qtivtransform: Video transformer
typefindfunctions: image/x-quicktime: qif, qtif, qti
而Debian13只有一个 typefindfunctions: image/x-quicktime: qif, qtif, qti
We have received your question, but our technical team is on holiday. We will get back to you as soon as the holiday is over.
当前已发布的Debian版本camera不支持预览,您可以连接imx219,执行下列命令,可以正常进行拍照/录像
拍照
export GST_PLUGIN_PATH=/usr/lib/gstreamer-1.0/:$GST_PLUGIN_PATH
export LD_LIBRARY_PATH=/usr/lib
gst-launch-1.0 -e qtiqmmfsrc camera=0 name=qmmf ! image/jpeg,width=1920,height=1080,framerate=30/1 ! multifilesink location=/opt/frame%d.jpg sync=true async=false max-files=2
拍照完成后在 /opt 目录下会生成对应的 frame%d.jpg 文件,如下图:
录像
gst-launch-1.0 -e qtiqmmfsrc camera=0 name=camsrc video_0::type=preview ! video/x-raw\(memory:GBM\),format=NV12,width=1920,height=1080,framerate=30/1,compression=ubwc,interlace-mode=progressive,colorimetry=bt601 ! queue ! v4l2h264enc capture-io-mode=5 output-io-mode=5 ! queue ! h264parse ! mp4mux ! queue ! filesink location="/opt/mux0.mp4"
视频保存为 /opt/mux0.mp4,如下图
原来是要用root用户才行 :face_with_tears_of_joy:
还有 AI 处理器和 SDK 的测试方法 | RUBIK Pi Documentation 这里也是要用root用户才行
切换root用户可以体验更多功能以及开启命令补全,建议您在debug之前切换root用户
好的,谢谢。
顺便记录一下,普通用户跑dsp的话需要把/dev/fastrpc-* 改为666就可以了。
感谢您的分享
