编译Yocto工程失败,QCM6490_fw.zip文件不对
DEBUG: Executing python function extend_recipe_sysroot
NOTE: Direct dependencies are [‘virtual:native:/home/luo/workspace/build-qcom-wayland/conf/../../layers/poky/meta/recipes-extended/unzip/unzip_6.0.bb:do_populate_sysroot’]
NOTE: Installed into sysroot:
NOTE: Skipping as already exists in sysroot: [‘unzip-native’]
DEBUG: Python function extend_recipe_sysroot finished
DEBUG: Executing python function do_unpack
DEBUG: Executing python function base_do_unpack
NOTE: Unpacking /home/luo/workspace/src/vendor/thundercomm/prebuilt/BP-BINs/QCM6490_fw.zip to /home/luo/workspace/build-qcom-wayland/tmp-glibc/work/qcm6490-qcom-linux/firmware-qcom-hlosfw/1.0-r0/
[/home/luo/workspace/src/vendor/thundercomm/prebuilt/BP-BINs/QCM6490_fw.zip]
End-of-central-directory signature not found. Either this file is not
a zipfile, or it constitutes one disk of a multi-part archive. In the
latter case the central directory and zipfile comment will be found on
the last disk(s) of this archive.
unzip: cannot find zipfile directory in one of /home/luo/workspace/src/vendor/thundercomm/prebuilt/BP-BINs/QCM6490_fw.zip or
/home/luo/workspace/src/vendor/thundercomm/prebuilt/BP-BINs/QCM6490_fw.zip.zip, and cannot find /home/luo/workspace/src/vendor/thundercomm/prebuilt/BP-BINs/QCM6490_fw.zip.ZIP, period.
ERROR: Bitbake Fetcher Error: UnpackError(‘Unpack command PATH=“/home/luo/workspace/build-qcom-wayland/tmp-glibc/sysroots-uninative/x86_64-linux/usr/bin:/home/luo/workspace/layers/poky/scripts:/home/luo/workspace/build-qcom-wayland/tmp-glibc/work/qcm6490-qcom-linux/firmware-qcom-hlosfw/1.0-r0/recipe-sysroot-native/usr/bin/aarch64-qcom-linux:/home/luo/workspace/build-qcom-wayland/tmp-glibc/work/qcm6490-qcom-linux/firmware-qcom-hlosfw/1.0-r0/recipe-sysroot/usr/bin/crossscripts:/home/luo/workspace/build-qcom-wayland/tmp-glibc/work/qcm6490-qcom-linux/firmware-qcom-hlosfw/1.0-r0/recipe-sysroot-native/usr/sbin:/home/luo/workspace/build-qcom-wayland/tmp-glibc/work/qcm6490-qcom-linux/firmware-qcom-hlosfw/1.0-r0/recipe-sysroot-native/usr/bin:/home/luo/workspace/build-qcom-wayland/tmp-glibc/work/qcm6490-qcom-linux/firmware-qcom-hlosfw/1.0-r0/recipe-sysroot-native/sbin:/home/luo/workspace/build-qcom-wayland/tmp-glibc/work/qcm6490-qcom-linux/firmware-qcom-hlosfw/1.0-r0/recipe-sysroot-native/bin:/home/luo/workspace/layers/poky/bitbake/bin:/home/luo/workspace/build-qcom-wayland/tmp-glibc/hosttools” unzip -q -o '/home/luo/workspace/src/vendor/thundercomm/prebuilt/BP-BINs/QCM6490_fw.zip' failed with return value 9’, ‘file:///home/luo/workspace/src/vendor/thundercomm/prebuilt/BP-BINs/QCM6490_fw.zip’)
DEBUG: Python function base_do_unpack finished
看起来文件损坏了
git lfs pull
OK了,下载速度特别慢,只有20KB/s,下载了一天才下载下来。
