插上hdmi接口后不显示,不论是desktop 还是server版本,是不是没有相应的edid
屏幕是微雪 21.5inch FHD Monitor
请上传一份完整的dmesg log
➜ ~ sudo dmesg | grep lt9611
[ 15.346446] lt9611 9-0039: supply vdd not found, using dummy regulator
[ 15.346595] lt9611 9-0039: supply vcc not found, using dummy regulator
[ 15.535941] lt9611 9-0039: LT9611 revision: 0xe2
[ 15.539934] lt9611 9-0039: supply vdd not found, using dummy regulator
[ 15.542326] lt9611 9-0039: supply vcc not found, using dummy regulator
[ 15.728329] lt9611 9-0039: LT9611 revision: 0xe2
[ 16.006339] lt9611 9-0039: supply vdd not found, using dummy regulator
[ 16.009955] lt9611 9-0039: supply vcc not found, using dummy regulator
[ 16.193039] lt9611 9-0039: LT9611 revision: 0xe2
[ 16.201910] lt9611 9-0039: supply vdd not found, using dummy regulator
[ 16.202092] lt9611 9-0039: supply vcc not found, using dummy regulator
[ 16.383886] lt9611 9-0039: LT9611 revision: 0xe2
[ 18.285738] Modules linked in: q6apm_dai q6apm_lpass_dais q6prm_clocks snd_q6dsp_common q6prm audio_pkt binfmt_misc nls_iso8859_1 snd_soc_hdmi_codec msm_audio_mem ucsi_glink rpmsg_ctrl pmic_glink_altmode snd_q6apm spf_core qcom_battmgr aux_hpd_bridge typec_ucsi qrtr_smd fastrpc rpmsg_char qmi_cooling brcmfmac_wcc msm snd_soc_es8316 hci_uart snd_seq_midi btqca snd_soc_qcm6490 snd_seq_midi_event snd_soc_qcom_sdw btrtl snd_soc_qcom_common btsdio btintel snd_rawmidi snd_soc_simple_card_utils btbcm snd_soc_msm_stub soundwire_bus bluetooth brcmfmac snd_soc_core ecdh_generic qcom_spmi_adc5 snd_compress pm8xxx_vibrator leds_qcom_lpg ac97_bus pm8941_pwrkey qcom_spmi_adc_tm5 led_class_multicolor ff_memless qcom_vadc_common qcom_spmi_temp_alarm ecc industrialio snd_pcm_dmaengine snd_seq snd_pcm brcmutil ocmem gpu_sched snd_seq_device cfg80211 drm_exec snd_timer iris_vpu drm_display_helper drm_dp_aux_bus cec snd lontium_lt9611 qcom_tsens v4l2_mem2mem rc_core videobuf2_v4l2 soundcore videodev qcom_edac videobuf2_common mc gpi
➜ ~ sudo dmesg | grep hdmi
[ 0.570218] /soc@0/geniqup@ac0000/i2c@a84000/hdmi-bridge@39: Fixed dependency cycle(s) with /soc@0/display-subsystem@ae00000/dsi@ae94000
[ 1.621132] /soc@0/display-subsystem@ae00000/dsi@ae94000: Fixed dependency cycle(s) with /soc@0/geniqup@ac0000/i2c@a84000/hdmi-bridge@39
[ 1.961930] /soc@0/geniqup@ac0000/i2c@a84000/hdmi-bridge@39: Fixed dependency cycle(s) with /soc@0/display-subsystem@ae00000/dsi@ae94000
[ 3.453010] /soc@0/display-subsystem@ae00000/dsi@ae94000: Fixed dependency cycle(s) with /soc@0/geniqup@ac0000/i2c@a84000/hdmi-bridge@39
[ 3.865374] /soc@0/geniqup@ac0000/i2c@a84000/hdmi-bridge@39: Fixed dependency cycle(s) with /hdmi-connector
[ 3.878204] /hdmi-connector: Fixed dependency cycle(s) with /soc@0/geniqup@ac0000/i2c@a84000/hdmi-bridge@39
[ 5.218349] /soc@0/geniqup@ac0000/i2c@a84000/hdmi-bridge@39: Fixed dependency cycle(s) with /hdmi-connector
[ 5.218462] /soc@0/geniqup@ac0000/i2c@a84000/hdmi-bridge@39: Fixed dependency cycle(s) with /soc@0/display-subsystem@ae00000/dsi@ae94000
[ 5.624212] /hdmi-connector: Fixed dependency cycle(s) with /soc@0/geniqup@ac0000/i2c@a84000/hdmi-bridge@39
[ 5.634300] /soc@0/display-subsystem@ae00000/dsi@ae94000: Fixed dependency cycle(s) with /soc@0/geniqup@ac0000/i2c@a84000/hdmi-bridge@39
[ 5.646929] /soc@0/geniqup@ac0000/i2c@a84000/hdmi-bridge@39: Fixed dependency cycle(s) with /hdmi-connector
[ 5.656982] /soc@0/geniqup@ac0000/i2c@a84000/hdmi-bridge@39: Fixed dependency cycle(s) with /soc@0/display-subsystem@ae00000/dsi@ae94000
[ 15.838089] /soc@0/geniqup@ac0000/i2c@a84000/hdmi-bridge@39: Fixed dependency cycle(s) with /soc@0/display-subsystem@ae00000/dsi@ae94000
[ 15.851339] /soc@0/display-subsystem@ae00000/dsi@ae94000: Fixed dependency cycle(s) with /soc@0/geniqup@ac0000/i2c@a84000/hdmi-bridge@39
可以分享一下完整的dmesg log吗
